C6F searching for a part
Danmark
- Véhicule N° 1 : C6F
- Numéro de série 1er véhicule : 58334
- Véhicule N° 2 : Citroen B2
- Numéro de série 2éme véhicule : 88
I am restoring a C6F from 1930 and in that context I'm searching for another steeringhouse for it. If anyone knows where I can find that, please let me know. I'm also searching for an idea on how to repair the steeringhouse because there is a lot of play in the steeringmechanism. More than 10 cm on the steeringwheel.
Danmark
Re: C6F searching for a part
Here is the photo of the part I'm seaching for. The rat strain is directly connected into the steeringhouse on this model.
Bonsoir et bienvenue
Il faut savoir que ces boitiers de direction ont tous du jeu meme en parfait état .
Apres on peut agir sur les 3 reglages différents .
Utilise l'onglet en haut a droite pour selectionner la langue de l'ecriture comme cela la traduction sera en DANOIS .
Brug fanen i øverste højre hjørne til at vælge skrivesproget, så oversættelsen bliver på DANSK.
Danmark
Thank you for your feedback, but I think that more than 10cm on the steering wheel is to much.
Have someone experience with repair or an were I can find an ajusting procedure.
best regards
Dan
best regards
Dan
